I will and always will recommend using coolant that is compatible.
The chemistry between coolants can be dramatic. Yes the pressure cap adds most of your boil over protection but antifreeze does add some.
I know a few chemical engineers they are far from stupid.
They weren't using too many aluminum blocks in the 60s, and I'm pretty sure they didn't have graphite blocks/cylinder heads.
Your car your choice but I will never recommend universal anything to anybody.
www.fleetequipmentmag.com
www.autoserviceworld.com
Coolant compatibility: Know thy coolants
When it comes to a fleet’s extended life coolant concerns, look no further than the three C’s: Capabilities; Compatibility; and Contamination. The biggest concern for the fleets running organic acid coolants (OAT) and nitrited organic acid technology (NOAT) extended life coolant [ELC] is knowing...
Coolant Compatibility a Hot Topic - Auto Service World
Few things will get an OEM engineer hot under the collar faster than suggesting that there is no difference in coolant formulations.At least that's if you
Understanding the Different Antifreeze Types for Your Car - Irontite Additives
Are you looking for the right engine coolant for your car? Keep on reading this post to know the different antifreeze types and how they're made.
www.google.com
