1 - 5 of 5 Posts
This may be an easy answer but I have been searching in vain trying to found out if the 2001 SOHC and DOHC Focus engines use the same connecting rod. My searches so far say probably Yes but I need to verify. A stupid mistake by yourstruly requires me to get new rods for the 2001 Zetek I am rebuilding.
Thanks for any input!
Cheers!
CurtisS
Likely not. I found that the rod length is different, so is the compression height. Zetec rods earlier than '98 are different from zetec of '98 and later too.
https://performanceparts.ford.com/download/pdfs/EngineDimensions.pdf
Check 2.0 CVH (SOHC) against 2.0 zetec there. Looks like rod journal size may have changed too, I found that elsewhere.
Thanks for this information, amc49. This gives me more to work with especially knowing the 95-04 Zetecs are the same. Now to find a source!
Cheers!
CurtisS
95-04 zetecs are NOT the same, I just told you that. The rods alone changed length to match a changed piston height and only one of many differences, the front cam timing gear, mount, water pump are wildly different too. You have to read footnotes 7 and 8.
Sorry, Missed the footnotes. My wife tells me I don't listen very well too.
Thanks.
1 - 5 of 5 Posts
