1 - 6 of 6 Posts
My SVT died and I got into it today and it appears to be a rod bearing or the rod to be broke because the piston head connected pretty good with the spark plug.
Now I have a couple questions, should I get a rebuilt motor and replace the whole thing or just replace the bearings and piston?
And if just the bearings and piston, where can I find them?
Any help or advice would be awesome. I just had my timing belt and water pump done like 2 weeks ago, so this is getting pretty outrageously expensive.
Thanks!
C2H5OH
If a piston hit a plug, sorry to say but you'll be needing new valves too.
I'd have to think the timing belt is the cause and not a bearing.
I guess I'd start shopping for a new/used engine vs rebuilding one. Might get lucky and find one, and it should be cheaper than a rebuild.
FF Affiliate
If you piston hit the spk plug then you bearing went out and killed the crank shaft , rod , piston , more then likely bent valves and on and on
A rebuilt engine or used would be your best bet if you dont have the ability to build it your self
Discussion Starter · #4 ·
best places to get replacement engineanyone?
I have a motor that just turned 100k im looking to sell the pistons and rods out of. im looking to go fi. and i just pulled the motor last night. let of know
Posted via FF Mobile
1 - 6 of 6 Posts
