Lol. I have never used a torque wrench on a valve cover gasket. Normal procedure on any focus valve cover is the center first if it has middle bolts in between the spark plugs. Then you criss cross from the center to the ends. I use a 1/4 inch drive socket and work them all in finger tight first. And work my way to snug in the middle. Then the outside bolts. Once I feel the bolts starting to give me some evidence the gasket is snug, I go for a full tightening in the same order. Remeber the torque specs are for a new engine. Clean all of the oil out of the bolt holes and bolts with brake clean and make sure you do the same to the cover and the head surface. Most repeat valve cover oil leaks are from a failure to completely remove the old gasket sealer. The grooves in the valve cover I clean with a wire brush on my dremel.
