1 - 3 of 3 Posts
If you look in your owner's manual it will give you a Ford Spec lube. Write that down, then look for it on the back of the bottle you choose. If you don't see it, then you need to find another fluid. If you pick a MerconV first, you won't look further.
Thanks for the reply and I should have phrased my question better. It appears Ford has decided that Mercon LV is OK to use in the 4F27E according to this Ford Automatic Transmission Fluid Chart Has anyone done this cause I thought Mercon V and Mercon LV were not compatible?
1 - 3 of 3 Posts
