1 - 20 of 23 Posts
Okay.. so. My 2002 SVTf does not like to start up in the morning, its kind of annoying. When I crank it over, sorta sputters for a few seconds THEN it starts. But once its running its misfirering and running shitty, untill its warm. Once its warm it runs great. Maybe a pugged up cat?
Maybe just plugs or plug wires...Are they original? Wires are only good for 5 or 6 years or so.
A plugged cat would give shitty performance hot or cold.
My 03 does the same thing no sputtered in the beginning but runs terribly until warm some answers would be great my plugs and wires have also been changed but I guess i should take a look since it was the last owner that changed them and he didn't seem to smart..
I've got the same issue as well, only on cold starts and its turns over for a while, then fires and stumbles for a bit. I've got fairly new plugs and wires also, I replaced them this summer. I have no idea what the issue is either. Hopefully someone can help us out!
I think it is the cold snap we've been having... mine does it also. I've noticed (last year) that when I plug in the block heater (at least 2 hrs), it starts a lot better no matter how cold it is.
have you guys thought of changing the fuel filter... i had almost no mid to high end power with a rough idle.. and then replaced the fuel filter. i couldn't even blow threw that thing... my 02 svtf has 120,xxx on it and that sucker was clogged... let me know if you need the alldata sheet on it.
Same issue here and only 19k on my 02 focus. I'm logging data and the fuel ratio is up to 16.5:1-17:1 when this is happening. I'm wondering if these are a symptom or a cause. Changed both O2 sensors and still there. Fuel is my new prime suspect along with vacuum related issue.
Keep me posted if you come up with anything and I'll do the same.
Discussion Starter #11
I figured it out!.. The intake runner on my foci sticks open on occasion. When I start my car up and the intake runner is open, it sputters and idles really poorly. Usually shutting the car off and restarting fixes the issue :).
FF Affiliate
Intake runners open / closed / stuck part way would cause cold start issues
This is all tuning related or a bad sensor either way a tune / flasher will cure these issues and make your SVT idle , drive , cruise , perform , MPG better
^^^^ what Tom said, my 02 svtf always ran rough and misfired when cold at first startup, I got toms tune now and it a whole different car. No more rough idle when cold also.
Well, it is in fact already running Tom's tune...lol
This has only happened after being parked for 2 years. Prior to that it ran mint.
Tom....maybe we can data log and maybe you can see something going on?
What parameters should I log? All fuel? All ignition?
I kinda forget how to save and upload the log file Tom! Any help would be appreciated .
FF Affiliate
If you have a laptop and internet to your car I can take over your laptop , set everything up and do a datalog just like I was sitting in the car with you
1 - 20 of 23 Posts
