Hi all, I've recently installed a set of D2 coilover. now, the setup is that it is adjusted all the way up coz I like some of the clearance (no 45 angle at speed bump or crawl up a driveway hoping ot doesn't scraoe). there is very little droop on the suspension. I could lift the car couple if inches and have clearance from ground. thoe only other person I know that has used this brand is tantalus, and I don't know where he is,
now if the shocks are "topping" out ie the shock pistons(I think) would at the lowest possible pooint and used for DD what whould happen? it's not adjusted all the way up, it still has some travel, but say if the wheel hit a manhole cover or a dip then quickly a bump after, I would hear a thud (sound like it, can't really expaining it)
I know what effect is bottoming out - ie shock pistons hit top of tube, what would happen if you topping out - ie shock pistons hit the bottom of tube?
just kinda worry about it. thjanks
