1 - 20 of 26 Posts
2012 SEL, Mileage 50709
what was done:
1 BV6Z*7B546*D CLUTCH ASY
1 CA6Z*7A508*E CYLINDER ASY - CLUTCH SLAVE
1 XT*11*QDC FLUID TRANSMISSION
1 EV6Z*7052*A SEAL ASY - OIL
All covered under warranty. The car is driving better than it ever has...smooth as butter. That's the good news.
Bad news is after asking for an alignment found out I needed and upper control arm.
1 BV6Z*5500*E ARM ASY - REAR SUSPENSION
Part cost 59.00. Labor 280.00!
total cost 339.00!
I find it highly unusual that I would need this part after only 50,000 miles, but having just bought new firestone tires 2 months ago with lifetime alignment, and being told by the tire shop that they can't fix the rear camber, I don't want them to be ruined because of bad camber/ alignment issues. Had to be fixed.
All told the Ford dealership handled things very well and my service Manager was very friendly and professional throughout the process.
I'm not ready to give up on this car, and now that it is driving like new again I hope to have it for several more years to come.
#dailydriven
Awesome. always good to hear positive stories.
Do you drive the DCT?
Why the clutch it's under warranty and the upper control arm... Don't?
You can always get the OEM $59 part and have an independent mechanic to make the job and save some money...
3rd Time's the Charm
Clutch Slave cylinder tells me MTX. What was the initial issue with shifting?
I don't think SELs were ever offered in manual. Also, this TSB wouldn't apply to a manual either.
In the U.S. no SEL manuals, but in Canada they did sell an SEL with a manual, though not likely to be in Florida even used.
Discussion Starter · #7 · (Edited)
same issue as most of the DCT's from 2012 models. Hesitates and shudders when accelerating. More than it should.
550 rpms of clutch slip, shaft seals leaking onto bell housing and clutch levers.
Discussion Starter · #8 ·
I doubt I would saved all that much money having another mechanic install it. And warranties usually don't cover things related to tires/suspension.
It does seem odd that the entire control arm needed replaced, and not just some bushings...but I am pretty ignorant when it comes to suspension and things of that nature. And again, most of the cost was labor and not the part.
I have read that this is a fairly common issue with ford focus, even mk1 and mk2 models, as well as F series trucks.
The bushings in the control arms haven't been a replaceable item in any of the Focus models. In prev. versions there WAS a replacement upper arm for Wagons with camber out of spec. (too much), haven't heard yet of a Ford one like that for any other model.
CunFFS13 could have read closer & noticed the mileage, at 50,000 it's out of the full warranty period.
The "slave cyl." description does sound odd, but I wouldn't know what names they might use for all the parts of the clutch actuator system (dual).
Healthy labor total, I hope that includes the alignment?
Mine is in the shop today, for reprogramming the xmission...I just want the clutch plates replaced, but Ford & dealer say it needs programming first.
Got my car back this afternoon, the xmission is reprogrammed, but still fails...the rebuild parts have been ordered, but will not be here until 08 September at the earliest :-( .....
So I'm stuck with a messed up xmission until then :-(
At least I'm in queue for repairs
Discussion Starter · #12 ·
Good luck with your repairs. I had the reprogram done as well and knew right away that it made absolutely zero difference to the DCT performance.
Never had the transmission malfunction indicator turn on though...that's actually the first time iv'e seen that.
I too had to wait several weeks for the clutch replacement due to transmission techs in the service department having a backlog of repairs. [?|]
Between the fiesta and the focus they have job security for the next 5 years at least [giddy]
I want to look into this further. Please send me a private message with your VIN, mileage, best daytime phone number, full name, and dealer name/location.
Meagan
Meagan:
thank you, I will do so later today or over the weekend
Transmission Shudder
Meagan
I have sent you a p.m. regarding a similar experience with my 2014 Focus SE.
Thank you!
Issues worsened with lurching and grinding noises
I have had my Focus for about a year and a half. I did learn how to drive it like a stick with manual transmission and it did okay. Recently though, my wife took a short trip(about 150 miles) and after she returned I got in the driver seat and after taking off as I normally do, the car began to lurch and buck with a louder than usual grinding/low frequency vibration that went along with the bucking and lurching. This behavior continued while driving straight, turning corners, and taking off from a stop.
I have had it back to the dealership several times for noises related to the transmission and they have retuned it and checked it out. The last time they did not take it into the shop, rather the tech took a ride with me. all I got is that this is normal for the car to run this way.
I strongly disagree and would like to have the car fixed properly.
You need to take it to a different dealership. They should be doing the latest TCM update with the diagnostics, then running it and checking for it being in/out of spec. My clutches were ordered on Friday. The service advisor wasn't the least bit surprised by my concern. They acted like it was 'normal' for these cars to have trans issues, not the other way around.
1 - 20 of 26 Posts
