1 - 2 of 2 Posts
Hi
I was wondering if anybody can offer any advice i have a ford focus ghia 2.0 L X Reg when the car has been driven at speed it revs when the clutch is pressed to approx 4000 rpm. The clutch is biting high but drives ok any other time. Could anybody tell me if they are related and if the whole clutch needs replacing and if it is is it likely anything else will need doing. Not had much luck with garages and don't want to be charged for a full clutch if this might not be needed.
Many thanks
Trump 2016
it sounds like a clutch promblem also depends on mileage if not beating on clutch maybe after 1000000 miles definetly change you should also change the throw out bearing
1 - 2 of 2 Posts
