1 - 2 of 2 Posts
so i just put in the spec stage 2 w/ alum flywheel and went to bleed the clutch and there is no pedal feel even after the clutch was bled. Basically it feels like the spring for the pedal is the only resistance on it. I think my master cylinder is bad might that be it? I'm hoping I don't have to take the tranny out again because I really don't wanna do that. Does anyone know?
MW2 NE1?
when replacing a part in the trans. best change other parts that you need as well to avoid having to take it out again. you should have just got the whole clutch n flywheel set that comes with the master cylinder from c-f-m.com. thats where i order my replacement parts.
1 - 2 of 2 Posts
