My transmission is very difficult to shift into gear from neutral and the colder the day, the worse it is. It's been doing this for a long time, but its been getting worse. In the past, if I get it into third first, it would go into first just fine. Not anymore.
It seems like once the clutch is released in neutral, the flywheel and disc do not separate properly.
Status: engine on, vehicle stopped.
1. shifter in neutral, clutch released.
2. Clutch pressed in, shift into third. It goes in with a lot of resistance.
3. Maintain clutch pressed in. Shift from 3rd to 1st. There is a lot of resistance.
4. With clutch still in, slowly pull gear out of 1st. Grinding is heard.
So, here is what I am thinking...
The car is stopped and clutch is pressed in, so the engine is separated and transmission input shaft comes to a halt once the gear goes into 3rd. Since the clutch remains pressed in and not released past step 2, there shouldn't be any resistance going into 1st after having been put into 3rd to stop the shaft. I think the resistance and grinding indicates the input shaft picking up RPMs again due to clutch disc rubbing up against the flywheel.
If the clutch has not been released in neutral after starting, the stiffness does not occur, so it seems that the clutch system has issues disengaging with the clutch disc/pressure plate assembly in rotation (as in the case of shifting into a gear after the clutch has been released in neutral allowing the input shaft to spin up)
Engine off, Gear still in third and clutch to the floor. Start engine. There is no resistance in shifter going into first.
When the engine is shut off between step 2 and 3, there is also zero resistance
The very first shift from spinning input shaft to a gear could be a synchro issues, but I fail to understand why there is a substantial resistance in going into another gear with the clutch pressed in(disengaged) after its already been in one gear; unless the clutch is not fully disengaging and causing the shaft to spin back up as the shifter is moved through neutral.
I found a very similar complaint here:
http://www.justanswer.com/ford/4ahsn-ford-focus-s-2007-ford-focus-w-approx-47-000-miles-just.html
I've also found that shaft bearing squeals when cold. (Start car in neutral, no sound, squealing starts once clutch is released in neutral)
Anyone else have a similar problem? It's not a cheap task to get the transmission dropped, so I'd like to have a better idea before committing to it.
