1 - 15 of 15 Posts
2007, 2.0 S, 5-speed:
I began trying to replace my leaking clutch master cylinder over the past two
days. I cannot remove the main hydraulic line from the existing clutch master
cylinder. I have removed both retaining pins, soaked the parts in PBlaster and
some brake fluid, and have pulled, pushed, pryed, and picked for about 8 hours total. I have managed to open a gap about the width of a penny.
I really do not wish to have to cut it, or have the car towed to a shop.
I realize it would be wise to replace the line. I am certainly considering towing it to a shop to fix a new line because I do not have the special tools or know the measurements of the main line to do it myself. I do not wish to go through this hassle again should I have to replace another leaking clutch master cylinder again.
Does anyone have any advice? I do not want to give up.
As for Plan B, I looked into this Forum for possible clutch master cylinder line measurements. I assumed they would be the same as brake lines, so I read Zetec brake lines were 3/16". Is 3/16 safe to assume for CMC lines? Can this be confirmed, please.
[idea] I am at my wits end. Any suggestions and advice is appreciated.
If you mean the lower line that runs to the clutch, there is a line holder just below where the line leaves the MC.
It will usually fight you if you don't have the line out of the holder, but, sometimes the holder has helped me pull more straight out the line and pop it out easier.
Try both ways.
It will dislodge and pop out.
When it finally does, it will probably do so easily.
They are just weird like that.
If you pull on it with any slight angle at all in your force, it will not pull out; you must pull perfectly straight.
Just stay calm and cool and give it only a little rotation back and forth while you pull perfectly straight out.
If the MC is loose from the firewall, it will be tough to do as well.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Also, make sure you have your fuse box out of the way so you are approaching it from directly above.
Apologies if you're already doing so.
Just trying to think of what can hose that job.
And of course, take your pick and really triple check yourself that you do indeed have the clip out of that one.
Thanks for your replies.
The fuse box, battery tray, and transmission mounts are out. I have removed the C clips. I even thought there might be two somehow so I blindly felt the underside with a pick to be sure there are no other retainers.
I have tried to pull as straight as possible initially, but I did just go nuts on it after it would not budge. The line holder came out first without me having to intentionally remove it. The CMC was bolted on still, but now there is play and clicking sounds if I push the line in and out as if I have stripped something. I am not sure. I will keep trying.
Anyone think there is a way to remove from the inside?
Discussion Starter #6 (Edited)
This report is delayed, so I will conclude this thread.
After many attempts, I ended up the disconnecting the lower hydraulic line from the clutch master cylinder using a dime, quarter, nickel and dollar coin. As stupid as it sounds, it worked. I worked the dime and wedged it to make an increasing gap between the hydraulic line until they started to bend out of shape. Then I used slightly-angled needle nose pliers and continued wedging back and forth until it finally disconnected with one last yank. It was not the o-ring that created such a hassle, but bloated rust. I have a picture but I cannot upload at the moment.
I advise those who are going dealing with rusted hydraulic line connections to just cut the damn thing out with the clutch master cylinder because Ford only sells the complete hydraulic line (slave cylinder to c.m.c) as one part despite the three connection points, unless you wanna be a clown like me and test the usefulness of a dime! honk honk
Also, I coated the male ends and c-clips with some anti-seize at the thickest part to avoid contaminated the brake fluid (male end tapers in). This is not recommended, but I do not ever want to go through that crap again should the c.m.c fail in the future. So far so good. If the risk I took were to be a problem, I expect it to be after quite some time. I will update if I ever find contamination in the brake fluid.
Discussion Starter #8
3S4Z-7A512-CA
5S4Z-7A512-AA
all the c-clips were included
and i forgot to mention on my last post that pay extra attention to how you remove the c-clips. when you replace the clip, you should not feel like you have to force them in.
3S4Z-7A512-CA
5S4Z-7A512-AA
Which pn line is for what function?
Thanks
Paul
Discussion Starter #12 (Edited)
yes, because both are required to make the connection. idk why they made it this way, but they connect to each other to make one line which transfers brake fluid between the c.s.c and c.m.c. the connection cannot be made with just one of the two. the only difference that i noticed between these two parts was one is longer, non-flexible with two male-ends and the other that connects to the c.m.c is short and flexible having one female-end and one male-end. both part numbers are used as one to make one component of the clutch hydraulic system.
The line may well be split to make assembly faster on the assembly line. Both parts on the ends are already pre-assembled in more major assemblies. It then saves time on the line by allowing the last connection to go very fast.
Got it. Thanks
Paul
1 - 15 of 15 Posts
