i had the clutch changed. went ahead with a full setup clutch,pressure plate, flywheel, both master and slave got changed. Clutch works great, but now after my car sits over night or long periods of time while im at work etc. when i crank and start to go. it stumbles and then when i give it more gas finally picks up and goes normal. and i already had a low idle issue that got around 700 rpm at idle with ac on which made car shake bad. now if ac is on it drops to around 300-500 rpms and pretty much will stall if i dont give it gas. I don't even know where to start looking. I do have under drive pulleys on the car. but with ac off it will idle pretty much somewhat normal. all these started after clutch install. only other things i did was swap out water pump and flush radiator at same time as clutch install.
