1 - 17 of 17 Posts
2012 Ford Focus Ingot Grey SEL HB
Hey guys, I couldn’t find any subject on cluster upgrade on Google so I thought writing here would help me find an answer lol I was looking to upgrade the cluster on my 2012 Focus SEL to a more recent one... I really like the information the newer cluster gives such as digital speedometer or instant mpg etc. Would it be possible to upgrade it or it has other connectors and would not be compatible ?
Good question. I''m not sure about connections or anything of that nature. I wasn't able to find anything as well. It might be worth checking Forscan forums to see if someone was able to get that option toggled on via programming.
Good question, I was wondering the same about updating the 4 inch radio display to the colour one as well
I understand that all this requires is a firmware update. Some 2012's had been updated by dealers to solve a specific problem outlined by a TSB. There is another post on this forum that surfaced recently that documents how someone did the firmware update DIY. It still doesn't seem clearly defined to me and it relates to a USA build and I'm in Canada like yourself.
You are referring to upgrading the 4" radio display whereas the OP is referring to the 4" gauge cluster display. In 2013 they added an extra view that shows a 4 panel display and a few extras like digital speedometer and instant MPG. This is what he's looking to do.
As far as the radio display goes you can upgrade to an 8" OEM display or you can go with an aftermarket display. In both instances you are changing out the bezel. There's lots of information within this forum if you search it out.
The updated 4 inch screen I was talking about is the APIM. Mine is the first style which is the very basic blue lettering similar to the ones in the new fiesta. I was wondering if the more updated colour one in the same size would be a direct plug and play?
Here in Brazil 2014, 2015, 2016 models S, SE and SE+ comes with basic blue lettering and model Titanium comes with 4" color display. Some people changed S and SE with 4" and runs perfectly. But I don´t know if here is the same hardware and module that yours. Mine SE+ comes with 4" factory (only 2017).
Discussion Starter · #8 ·
Yeah, I thought I would be an option but it seemed too complicated... :eek:
Discussion Starter · #9 · (Edited)
After all, I found a ‘15 Focus ST in a local scrapyard! All the car parts were mostly gone such as the trims, spoilers, bumper covers and ST brandings(obviously).
But luckily, the cluster was still there!!!
305578
Then I dissembled the cluster and I found out that it was only a quick connector connected to the instrument cluster, one similar to the APIM connector with a lock but smaller.
My original cluster
305579
It connected flawlessly in my car (I have a 2012 Focus HB SEL)
And worked as it should, it recognized that my car was automatic but did not update to my actual mileage.
305580
Turns out you CAN swap the cluster without any trouble!
My original cluster
Awesome upgrade! I wonder if you would be able to upgrade to the ST steering wheel?
Your mileage i stored in the instrument cluster. Yes it's plug and play but you would have to get a cluster that has lower miles on it then yours and use forescan to up the miles to your miles on your car for that to be correct. Now if you have a 2012-2014 Focus and you install a 2015-2018 cluster with the digital speedo and you have a reverse sensing system, you will lose your beeping tones in the speakers as you get closer to backing up into something. Not sure why this is but it wont work. Second you can install a later model steering wheel onto your 2012-2014 car with no problems for the exception of the cruise control will not work, but everything else does. There is no way around getting the cruise to work with a 2015 and up wheel. The can bus wiring is going to different pins on the ABS module.
I did the wheel swap from 2018 escape onto my 2014 mk3 focus. To get all the buttons including cruise control to work i simply swapped the later model sams/clock spring module onto mine.
Direct plug and play on my 2014 mk3
What Happened???? :-o You're kidding me... So you're saying you took a 2018 Ford Escape Steering Angle Sensor Module and installed it on your 2014 Focus and was able to get the cruise control buttons to work??? With no programming??
No I took a 2017 focus sams/clockspring (square part that indicator and wiper stalks fit into) and put that on my 2014 focus sports. Put the escape steering wheel with paddle shifters on that with the matching airbag from the later model focus.
My original wheel button setup only had the bottom buttons on one side the same as the later model so everything worked plug and play except for the paddle shifters which had to have 3 wires fitted from the plug on the collumn to splice intonthe sport shifter harness on th
309670
e gear shifter to make them work.
Yes sure do. And the speed limiter buttons too.
StanE from the ST forums put me onto the fix. The newer mk 3.5 sams unit has slightly different wiring which immediately solved it for me.
Wow, i did this on my 2014 when i added the RS steering wheel and no matter what i did the cruise control would not work. I did install a 2016 SASM as well thinking that would make my cruise control work but it didn't work. In fact i couldn't center the steering wheel with Forscan. I got a message saying Hill Launch Assist Not Available. No matter what i did I could not get that SASM to work on my 2014, So this is why i converted my 2014 to a 2016 MY. Maybe because you are in Europe things are a little different with compatibility. :-/ But I'm glad you got it all working good. :) It turned out I'm glad i converted mine to a 2016 MY because i was able to install the Adaptive Cruise Control, Forward Collision Warning/Assist, PTC Heater, Auto Start Stop and Heated Steering Wheel. :-D And while my car was completely stripped down to the metal shell, i decided to have the car painted the Performance Blue that i was trying to find when i bought my 2014. But that color is rare and hard to get. So it worked out better for me in the long run. I got the car the way i wanted it now.
1 - 17 of 17 Posts
