1 - 4 of 4 Posts
I have a few charge air pipes that I need to clean up. One is metal dust from machine work(already tried blowing out with compressed air) and the other two have a lot of rust on the inside. Both pipes are too small in diameter to fit my hand in, and neither are straight. Any good ideas? Thanks.
You put enough shop rags together so it is a pretty tight fit in the pipe and then pull it through? Do you spray any type of cleaner or anything inside the pipe before doing this?
1 - 4 of 4 Posts
