For the glass, use a flat razor blade to scrape it off.I dont mean to jack this thread or anything but I've got some overspray on my car, both on the paint and on the glass. Will a clay bar work for both or what should i use to get the overspray off?
I had some over spray on my Fusion from when they painted the inside bottoms of the doors. (None of the door bottoms had a blue top coat on them, just primer). A Meguiar's standard grit clay bar worked fine removing the light over spray. As lyonsroar said, use a razor blade on the glass, a clay bar will also work on the glass, I once used one to remove hard water spots.I dont mean to jack this thread or anything but I've got some overspray on my car, both on the paint and on the glass. Will a clay bar work for both or what should i use to get the overspray off?
Use caution here!!! What kind of window cleaner are you talking about?? Be specific on brand.Window cleaner and water would work, too.
