1 - 20 of 22 Posts
Hello everyone,
I recently bought a 2001 Ford Focus ZX3 3 days ago[grinking] . The check engine [?|] .
engine light came on and I took the car to Autozone which they told me that
computer code which was P0420.
I googled the code and it kinda told me that it had to do with the 02 sensors
or the Catalyc converter not working properly.[?]
I was wondering if anyone has received this code before and how did they
resolve the issue??[pray]
Thanks for all your help in Advance...
John
Thanks for helping me out Penguin,
The current milage on my car is 72,380 miles..
I was thinking of replacing the O2 sensors, but honestly I was going to start with the
top one.
So if the 02 does not work then go ahead and change the cat??
Thanks in advace for all the help..
I am new to the Focus so I am just having fun..
Great forum..
> I was going to start with the top one.
It is the one after the cat that monitors the cat performance, and which I think would be the most likely culprit.
But here's some more info to digest:
http://www.obd-codes.com/p0420
http://www.tegger.com/hondafaq/p0420.html
http://www.alldatadiy.com/techtips/Toyota/20060131c.html
Good luck!
P.S. I believe the cat has an 80,000 mile warranty, but since you bought it used, it might not be covered, e.g., if somehow the prior owner(s) got some leaded gasoline into the vehicle, or if it was run a long-time with a prior misfire, or some other abuse., it would not be covered.
Discussion Starter · #5 ·
Thank you so much Penguin for the excellent advice.
I will replace the upper O2 sensor first on the car this comming weekend. If that does
not take care of the problem I will replace the Cat.
Since the cat is going to be very expensive then I will just ride with the yellow light for a
while if the 02 sensor is not the culprit.
Also I read all of the links very interesting.
Thanks again.
I just fixed a P0420 last week.. It was the catalytic converter. just over 100K miles. We looked at the O2 sensors during the replacing of the cat and they both seemed ok. I believe P0420 indicates the lower O2 sensor is switching in sync with the the upper one cos the cat isn't storing the oxygen, so it seems unlikely the sensors themselves have failed.. I think the PCM would pick up failed sensors and report their respective codes before it would report an 0420.
As mentioned above, the problem is what caused the cat to fail. I spose you could try and tell if it is blocked by disconnecting it from the exhaust manifold and seeing if the throttle response becomes much more lively.
btw if you're replacing the cat, you'll probably want a direct fit one unless you're very good at welding. Note also that most of the aftermarket direct fit ones dont really fit into the lower bracket for the stock cat, so the lower screws for the heatshield will not have anything to screw into (cos you end up having to leave the bracket off).
Be really interested if you can get it fixed under the 80,000 warranty. I think I read that stays with the vehicle regardless of the owner. Dunno how you prove the cat wasnt poisoned as penguin mentioned.
I thinks it's 8 years or 80.000 miles warranty. Here you can read more about it.
As far as I know it doesn't matter the number of owners or whatever, if the cat is still stock, and your car is under the mileage, they have to replace it for free.
Discussion Starter · #8 ·
Thanks everyone for the help.
Also do you know how much an aftermarket Cat cost?
I live in Dallas so any good places anyone can suggest?
Thanks
Number of owners doesn't matter, but if the prior owner abused it, such as getting some leaded gasoline in the engine, then obviously the warranty would be void.
Discussion Starter · #11 ·
Ok guys I went ahead and called the dealer. They stated that the Cat will be replaced
even though I am not the owner. This is a federal state law and has nothing to do with
the owner of the car. Also I just find out there is two recals open for my car.
Wohhoooo!!!!
FFForums rocks!!!!!!!!
Discussion Starter · #12 ·
CASE CLOSE.
I did a tune up on my car a long with replacing the PIG TAIL that was making a misifinrg issue in my car and whala no more engine light on. I think I fixed it. I have driven the car for 2 weeks and the light is not on anymore I will assume I have fixed the issue.
Ford Focus Rocks!!!
Thanks,
John
Discussion Starter · #13 ·
It sucks to say this, but I spoke too soon. The engine light came on this morning after a
gas fill up. Weird, but I will check into it this afternoon.
Discussion Starter · #15 ·
I checked the gas cap and nope its there nice a tight and nope the light did not go off. I will stopped by Autozone tonight and I will post my new code. I bet is going to be the old P0420.
Discussion Starter · #17 ·
Stopped by Autozone today and there is was behold P0420 I guess I will give up and dropp the money needed to get a new Cat...
Will keep you guys posted..
Discussion Starter · #19 ·
Genken my progress is as follows:
I have done a tune up, fixed a few vacum leaks, change all filters and change both O2 sensors. Last but not least I look into the recalls for my car at it said that the Catalyc converter was cover at 80,000 so I took it to the dealer and they said my car was covered, but since the car was totalled god knows how long my title had a rebuilt on it so they where not able to fix it for me. I talked to a muffler shop and they told me that it will run me about $600.00 to fix the catalyc converter. One thing I was told by a friend is go to a inspection site have them test it out and if the 02 is enriched then its definately the converter then call the local state office and they can help you with the fixing of the catalyc converter once a inspection site has determined that the catalyc converter is at fault. The only way they can help is if indeed you have proof that is a part in the emission that failed the test.
1 - 20 of 22 Posts
