1 - 2 of 2 Posts
B1600 PATS, B1601 PATS & P0171 what these means when i scan my ford focus wagon for codes.. Im worried because the check engine light is on..
DTC P0606
For your B codes, try another chip key if you have one. The code is indicating a transponder/receiver communication problem.
The PATS (Passive Anti Theft System) uses a receiver mounted in a ring around the ignition lock cylinder. When the ignition key is turned, a signal is sent to the key and the transponder within the key "replies" with the correct code allowing the car to start. The code indicates the code is wrong, garbled or is not being transmitted. If the code is wrong, your PATS LED light in the center of the dash may be flashing during an attempted start.
P0171 is a lean fuel delivery condition.
Code lookup here: http://www.focusfanatics.com/forum/showthread.php?t=59286
1 - 2 of 2 Posts
