1 - 8 of 8 Posts
So i was told after i installed svt headers and exhaust the check engine light would come on. Since this is my daily driver i still want it dependable and the check engine light to only come on if i really need to check my engine. Also i was told id only get 10hp tops?? Plus i was told the timing could mess up? Thoughts and advice?
Discussion Starter · #4 ·
Well before I completely get it put on I want to make sure the check light engine light will work the way it's supposed to. A guy at the shop I go too said it will be on once header is changed.
Vince your Moderator
The SVT has no EGR valve. Are you using an SVT cat with your set up?
FF Affiliate
Yes you will get a light
The SVT header does not use EGR like the Zetec , causes a CEL , That CEL can be turned off in a tune
The SVT header installed on the Zetec for engine safety requires a custom tune and wide band air fuel gauge , some will say I am trying to sell you something but I am not , I have tuned dozens of SVT headers on the Zetec and you need a tune
You will have to mod the comnnection from SVT header to Zetec exh
You will hve to move the PS line
you will need a SVT dipstick and tube
Do all this and it will prove to be the #1 best mod you do
Discussion Starter · #7 ·
Yes I'll use an svt cat. And for Tom how would I get a tune to make the CFL work properly? Once svt headers are installed?
You can find more general info. on "tunes" in teh tuning section here & in Tom's "FocusPower" section of the Forum.
1 - 8 of 8 Posts
