I am about to change the fuel filter on my 02 focus and was wondering if I can do it with an almost full tank of gas or if the tank has to be empty. I'm not too comfortable messing with gas and would rather be safe than sorry. Thanks in advance.
That how to is exactly how they mention the task(except they remove the fuel line fuse) in the service manual.Foci_Fosho said:follow the howto located at
www.myfordfocus.com
gas in the fuel tank doesn't matter, the fuel lines are purged when you disconnect the fuel cut switch and start your car.... it'll stall in 5 seconds or until you hit the gas pedal, then it will stall.
remember to disconnect the battery before removing the filter.
Um how ?Foci_Fosho said:if you don't disconnect the battery, you will get a CEL.
