1 - 8 of 8 Posts
could someone tell me step by step how to replace the foucs 08 foglights
thanks because im gonna change mine to green and since i have blue headlights it would look cool
im not sure of the way jpscott did it, but after you read the link above to take the head lights off (but im pretty sure you already know how to do that because of your leds). if you look down the hole where the headlight sits a good 2 feet youll see the connector go into the fog light housing. you simply turn it to the left to unscrew it. i found taking the bulb off the connector is VERY difficult without using two pliers to hold each side then pull off. i ended up breaking the clip off both because it was too little of a space to work with, so i just electrical taped it back lol. jpscott might know an easier way though..
i did it just pull the black piece around the foglight and it pops out its so easy thanks JPSCOTT713
1 - 8 of 8 Posts
