][sadpanda]
I changed the rear pcv hose and the pcv valve and ---- no difference at all to my problem.
I know that stuff needed to be changed out because it was not in good shape - but it was a pain to get those hoses off - they are really hard to get to - and the man at the ford parts desk was idiotic - and it was a holiday weekend and took days to get the parts - and I smashed my thumb - and and and!!!!! and then it did not work.
So frustrating.
recap: when I start car engine idles very very rough. chugging like crazy - engine shaking around... sometimes dies. if I keep foot on the gas it evens out. if I can get it to stay running and shift into gear (any) it does not smooth out. It was only intermittent problem but a week ago it got worse all of the sudden and now has not gone away. turning a/c on and off does not seem to make a difference. no check engine light.
So I have two competing opinions here in real life. One is - I need to check and change my timing belt. Don't worry I am not going to try and change that myself LOL but I will take the cover off tomorrow and look at it. I have about 140,000 mi on car and to my knowledge it has never been changed so I know that is overdue.
Reason my friend thinks we should check that is - engine seems too hot - like after just a few minutes of running it is very hot - the temp gauge is fine but after just a minute or two running - chugging as it were - the heat is just radiating off the engine. Not like it feels normally. he says also maybe there is a sensor not right - like o2 sensor or throttle sensor - says it is too lean - too much air not enough gas making engine too hot.
(also and prob unrelated is that car gets too hot on our hottest summertime days - and it is HOT here - when driving in stop and go traffic in the afternoon - I was planning to drain and clean radiator and see it that worked or get new radiator - not sure if that is related - I have already had new hoses and thermostat on this radiator last summer)
OK other opinion is that computer is bad. My moms hubby is saying this on the basis of another car he had (not ford focus) having similar problem and lots of things tried never fixed it but changing out computer did. supposedly. problem here is that computer for my car would have to be programmed - not a cheap and easy thing to try.
I have changed out MAF sensor a few months ago. This bad idle has been bothering me for a couple of years at least. But it was only happening intermittently. Every time I have car in the shop I ask them to look at it - but they say it didn't recur when they had it so nothing they can do - which sounds like crap to me since they could have found that bad hose easier than I could but whatever. So anyway on one trip they said the mass air flow sensor needed cleaning and they did it and it was a lot better - only a few seconds of chugging instead of a couple of minutes before it evened out. after a while it started getting bad again so I cleaned it myself. with the special cleaner. it didnt really help and poking around is when I found the oil in spark plugs - thats when I changed out the valve cover gasket and all the plugs and coil and wires. and a friend helpfully cleaned my mass air flow sensor again with carb cleaner - which it says NOT to do but he said would be fine - and that thing never worked again. had to buy a new one. about $100. Thanks a lot!!!!
What would you folks do next?
thanks for all your patient help!
Georgiaberry
So frustrating.
Georgiaberry
