1 - 5 of 5 Posts
Hi all not sure where to post so ill put it here have a 1.4 focus 2001 and the open button on key is broke can lock and open boot with it tho, so question is how do i get a new fob? Seen them on ebay can i programme any key fob??
Moved to General Tech Chat
Welcome to FF!
It's trickier for you folks across the pond with a combined key & fob than for us with separate ones for that model year.
If the E-Bay replacement you're looking at swaps in your existing key blank & RFID chip all that's needed is to program the fob into the car system.
If it's a whole new assembly then you're dealing with getting the key cut & programming the key portion into the car as well. That needs two existing original type keys that work in the car now to do it yourself, a "cloned" key doesn't count for this process. (two existing plus the new one)
Cheers
Cool thanks ?ya was hoping for more info don't need key cut as the fob and key can be diconnect from each other hopefully might find an option any idea what ford themself would do??
Ford would probably sell you a whole new key assembly, and charge for cutting/programming.
Don't forget to swap the "chip" as well as the key to a new fob, car needs to "see" that by the lock to start.
1 - 5 of 5 Posts
