I have a 2000 Ford Focus, SOHC engine.
I've had this code on for a while, maybe for a year now. No typical symptoms though. In April I replaced the EGR valve and the EGR tube, thinking that there might have been carbon build-up in the tube or the valve was done. This didn't help.
After reading the forum I figured that DPFE sensor failure is the most common cause of this code. Replaced it yesterday, after 50 miles of driving the code came back up again, so that wasn't the issue.
So, I'm confused right now. Basically, the whole system is brand new - the valve, the tube, and the sensor. I'm guessing my last resort would be to replace the solenoid.
I tried checking the tube and valve by sucking on the vacuum hose - and it did shut down the engine, so the valve and the tube are fine.
I don't experience any typical EGR malfunction symptoms. The car doesn't idle, buckle or cough, it doesn't shut down the engine at the red lights. It is just the annoying orange light on the dashboard that is driving me crazy.
I would be very grateful for any advice. Most likely I am going to replace the solenoid and pray it will work out. Are there any links on how to replace the solenoid?
Maybe the issue with the stupid car computer that thinks I have a problem with the EGR when I actually don't?
P.S. I don't know if it is important information, but: up until April the car had both Cat-issue and EGR CEL codes on, but I didn't bother since there weren't really any symptoms. When I started fixing it, I saw that the EGR tube was blown in two parts and that was obviously the reason why the EGR light was on. Replacing the tube didn't help though.
