1 - 7 of 7 Posts
Read Only
went to the track last night and caught this code on the way into work this morning. says lean in bank 1. any ideas ladies and gentlemen?
Hey,I just posted about this same exact code.
Mine came up after installing my 4-2-1 header.
Check your pcv valve tubing at the elbow.
Mine had collapsed,curious if yours did too.....
Did you check this yet?
I forgot to mention its the lower pcv tubing,check at the elbow where it meets the manifold located behind and under the throttle body.
Have to reach a little,but you will find it.
Need Help,hit Me up....I has pics.
Read Only
Discussion Starter · #6 ·
no mine was the vacuum tubing i used to go from the cai to the valve cover it had piched and was not allowing the excess air to be sucked out from the head. i have since fixed it and so far so good. and its a k&n typhoon cai----btw freakin awsome set up. good for 10.20's in the 1/8th
I had the same problem, but mine was banks 1 and 3. Checked the couplers going into the intake manifold and 2 of them were not on fully, which caused a vacuum leak and my CEL. Check those and as DeuceCoupe said, also check the PCV valve.
1 - 7 of 7 Posts
