1 - 6 of 6 Posts
ok guys
bought me a cfm race cat, but having looked at my cat, it seems like im going to have trouble removing it
it almost looks as if its welded on, because were it connects to the header around the bottom of the flange, it looks like its one piece
the two bolts on the top look like i can just about remove them, the the bottom bolt just looks like a piece of metal rather then a bolt,
can anyone advise me on this??
does anyone else think that were the bottom bolt is, its been welded????
I don't know about the welding issue, but I had to use an impact wrench to get the bolts to budge. Yours looks pretty crazy. Maybe take it to an exhaust shop and just pay to have it done, may need to be torched off.
FF Affiliate
Cut or grind them off with a side grinder is what I do or go to a muffler shop and let then torch them off , have new bolts ( get stainless bolts nuts and washers ) and but the new bolts in , drive home then change it out
Take a magnet with you to get the stainless bolts , a magnet wont stick to good quality stainless
I've done a few of these.
Everyone covered it. They're beyond reusing. I don't even believe PB Blaster (can you get it in UK?) would help. An air wrench or cutting wheel will make short work of them. CFM cats are supposed to come with new hardware but IF you decide not to use stainless steel, you might want to use a good high temperature (1500 degree F) anti-seize lube on the new nuts and bolts.
1 - 6 of 6 Posts
