1 - 5 of 5 Posts
just to double check there are two sensers on the cat the top on is a air to fuel senser and the bottom one is for the O2 senser???
Discussion Starter · #4 ·
so both of the sensers on the cat can set off the check engine light or only the bottom one??
The bottom one will because it normally has a cat above it the top one won't with a race header because it doesn't have anything above it. As far as with stock parts if either sensor goes bad they will throw a light.
1 - 5 of 5 Posts
