Okay I just bought a 2014 Focus SE 5spd Hatchback two weeks ago. I'm enjoying it a lot but I have been spending some time bumming around the interwebs looking at performance parts. CAI's, exhaust, computer tunes, motor mounts etc.
What brought me to this forum in the first place was that there's only one CAI (the AEM) that has an EO# out there. I have read a few places that when it rains it can suck water up and stall the car because it's pointed towards the ground. This is less than ideal to say the least. Does anyone have a MkIII with the AEM installed in Socal? If so how do you like it? What kind of performance boost do you get (if any)? Does this void the warranty?
Also related to CAI. Is it just better to go buy a K&N Typhoon or Injen SP intake and then swap the factory air box back in when it comes time to actually have to smog the car? Won't it be 6 years before I finally have to actually smog the vehicle?
I've been reading several posts by a guy name Tom who seems to be have computer tunes for the Focus SE that will give moderate power gains and improve throttle response etc. Does this kind of thing prevent the car from being compliant with CARB regulations and passing smog tests? Does it void the warranty?
I understand as long as you're not effing around with the exhaust headers or changing out the cat you can get cat-back exhaust and be in line with CARB regulations. Is this correct?
I have seen several videos online and posts about swapping out the stock RMM in the Focus. Does this apply to the SE as well as the ST? Is swapping the RMM in the SE the same amount of labour and is it in the same place as it is on the ST?
Wow that's a lot of questions. Thanks in advance for any help.
