1 - 3 of 3 Posts
Car will not turn over... NOW FIXED
In getting ready to change the fuel filter I removed the r7 relay to the fuel pump then try to strt the car, but it did not turn over. so I put the relay back in and tryed it again and still dose not turn over.
So I undis the battery then changed the fuel filter. After I was done with that I hooked the batter back up and tred to start the car again... Same problem, Car will not turn over. Every thing else seems to work.
Anyone have any input on this?
Thanks for any help
I found out what happend.
When I was removing the relay the cover on the relay behind it came off. I jest put it back on and that was that, But when it came off the thin wire had broke on the relay.
I put the high beam relay in it's place and it started right up.
1 - 3 of 3 Posts
