1 - 4 of 4 Posts
Hey guys, need help with hard engine start.
Seems like the start has gotten harder as weather has cooled down. used to be a double start, now it takes 3 or 4 every morning.
Used to start well, had a problem with throttle stuttering under high electrical load which turned out to be a bad coil pack so i replaced that and the plugs which fixed that problem. a short while after that, this started to happen.
what can be ruled out:
coil pack
sparkplugs
checked battery (after driving, and in morning)
fuel pump and filter changed recently
maf and air filter cleaned recently
after doing battery, plugs, wires, coil, fuel filter and pump ive found no solution to this problem.
however, i have found that if i give the car the tiniest bit of throttle when starting up, it starts up just fine, and only requires 5 seconds or so of pedal down to warm up and stay on. works every time...
1 - 4 of 4 Posts
