1 - 11 of 11 Posts
I have a 2002 zx3 5sp. This mornin i started her up, instantky jump to 3500rpm n stayed there for approx. 30secs before settling at 1050rpm n then to 950rpm. On my way to work everytime i change gears, the car would stay at the high revs then come back down...coasting to a stop light produces the same results. 1 block from my office, i ran first to 4000rpm n the car stayed at that rev for 35 secs before settling down again...wat da hell is going on?
How many miles do you have on it?
Spray some carb cleaner around the TB and see if the idle goes down.
Check the vacuum lines on the back of the intake manifold. It's not uncommon for them to go bad.
^have you driven with your window down and listened to your engine while accelerating? does it make a funny 'hissing' sound at certain rpms? mine is kind of doing the same thing but it makes that hissing sound every now and then at certain rpms. i might have the same problem but i can't figure it out.
Discussion Starter · #10 ·
cant hear my engine because of the exhaust, did find a loose vacuum line n plugged it back in but the problem seems to persist...high idle n long delay before the revs come down...ran a scan n 2 things came up...O2 sensor which i'm aware of but now there's a code BANK1...??? do not know wat it means...I live in the tropics(Jamaica) and i had replaced the thermostat n housing but the car was still running hot so i removed the thermostat...it runs fine temp is at dead center when car is warm. The only other thing i can add is that the speedometer works sparidicoly...must times it's not working at all but when it does the car drives the same for a little bit but then i notice a surge like too much fuel or something car driveability is not immediatly responsive. Touch the accelerator n the revs stay then slowly come back down to idle. CNormal Driving n changing gears the revs stay up going into the next gear.
I have an American Focus zx3 zetec year 2002
try tightening all of the exhaust bolts, everything from the exhaust manifold to the back, and see if that works. it worked for me the first time i had this problem but now i have this other problem
1 - 11 of 11 Posts
