1 - 4 of 4 Posts
My car puked out enough coolant yesterday morning to completely drain the reservoir. It seems like 95% of what came out ended up on top of the transaxle case. I assume the leak must be fairly large because it only took about 5 minutes of driving for this to happen, and it was loud enough that I could hear gurgling in the cabin. The problem is though, I cannot seem to figure out where it is leaking from. I checked all of the hoses on that side of the motor, and if any of them are leaking it must be through a pin hole. The only other culprit would be the water outlet (part CP9Z-8K556-B). Has anyone ever heard of this failing?
Since there is clearly a leak somewhere but it's not readily apparent, it seems a pressure test is the next step.
1 - 4 of 4 Posts
