very rarely do i use my horn, other than when im double clicking the fob to lock it..which is fairly regular. On a side not, today my beep is working with the double touch. So its in and out...any tsb or anything about this? I feel like having a horn not working is somewhat of a hazard.How often do you use your horn? A few of us have had our horns stop working because of corrosion in the connector.
See the last post in this thread:
http://www.focusfanatics.com/forum/showthread.php?t=327244&page=4
Yes, I think it could be that as well.Could it be the door closed sensor? I know for some cars the double tap horn doesn't work if the hood or any door's sensor is not working or not reporting door closed even if the door is physically closed.
Try it. If one door is not closed correctly, or not closed at all, it'll double beep a lot slower. You know something is wrong in this case. It did happen 2 or 3 times to me.Yes, I think it could be that as well.
Have you been to your dealer to have this looked into? Please let me know, along with your mileage. I'll see how I can best assist.So as the title says...When I lock my car with 2 presses on the key fob, it is no longer beeping consistently. Sometimes it will beep and sometimes it wont. I make sure all the doors are closed and it still wont beep.
Actually our cars do have an alarm. The second key press is for lockconfirmation as Sailor pointed out.So, since our cars don't actually have a factory alarm, does the 2nd press honk do anything other than annoy the poop out of me? Sorry to phrase it facetiously, but I'm serious....
