1 - 4 of 4 Posts
My focus was making this weird squealing type noise whenever I'd drive through a rain puddle, or whenever it was raining. Now it makes the same noise upon startup, or most of the time when I run the fan for heat. It will also make the noise when the heat/fan is not on. It seems to be coming from the right side of the car. I did hit a deer a few years ago, but they supposedly fixed everything. Just noticed this noise the past year or so, real bad the last month or two. Any ideas/suggestions? I'm hoping this is a nusiance noise, not something that is dangerous.
Thanks!
Added 11/19/08:
Is this related??? I was at the bank today, and had the heat on, with driver's side window down. I noticed a noise, so I turned the heat off. The noise got less. I turned the heat on high, and the noise increased. I'm not sure how to describe the noise.
my fofo was doing this about a week ago but it's not now
my guess is that we are talking about something similiar so just wait it out and see if it goes away like mine did
It sounds like your accessory drive belt tensioner may be faulty and not tensioning the belt enough, or the belt is really old. Adding water/road splash onto the belt makes it slip. This can sometimes be more pronounced with a cold engine (engine expands just enough when hot and you won't get the noise). Get a wrench on the tensioner/idler pulley and make sure that it's moving freely (has spring action) in both directions, particularly for the car that got smacked.
1 - 4 of 4 Posts
