2002 Ztec -5 sp 155,xxx miles
After about 10 minutes running it starts occasionally dying, the motor cuts out, the tach and the speedo go to zero but the radio and other gauges stay on.
It usually is only for a second or two but sometimes longer, when I am rolling it starts back up on it's own, when it does it for longer while stopped I get nothing when I turn the key either...i then jump out and unhook and rehook the battery and it will start, not sure if that is doing it or just the time going by. I have reset the ECU just in case but did not help. Have no check engine light on either.
Did a forum search but did not find my specific issue.
Bad ECU?
Bad coli pack or something?
Any ideas would be helpful, thanks!
Bad ECU?
