I have a 2000 2.0 SOHC Focus SE with about 130,000 miles. A couple days ago as I left work the car had a rough idle and would not accelerate very well at all. It took a long time to get up to 55 miles an hour. I drove home and didn't drive it. I figured it could be spark plugs and wires so I replaced the spark plugs first. The car started but no change, still a rough idle with the RPM's dropping every 2 or 3 seconds then coming back up. I then replaced the wires, and no help. After starting it a couple more times it eventually would not start at all. It would crank but not start. So i then replaced the ignition coil. No help there.
I took each spark plug out and started the car to see if I had a spark...yes I had a spark on each plug. So i have spark.
My fuel pump is working, i can hear it filling up and sending gas. So i tried spraying starter fluid down the throttle body to see if gas was the problem (possibly the fuel filter) No start whatsoever.
Anyone have any ideas. I guess the timing belt could have broke. But wouldnt I have heard something when it broke? Is there anything else it could be?
And it wasn't like the car got progressively worse over time. It worked great since I have had it and when I left work that day this started.
Any ideas would be greatly appreciated.
