I have a 2002 Ford Focus 2.0i Ghia automatic (Zetec) with around 30,000 miles on the clock.
Recently I noticed that there is a small jerk when going from first to second gear. I checked the fluid level and it was overfilled (must have always been) but only by around 1/2 litre. I removed the 1/2 litre and it has improved some but there is still a 1/2 second pause after I
press the accelerator then the car gives a small jerk when going from first to second. It is worse when my engine is hot.
I have not noticed this before, is it normal?
I am concerned that this could be the start of a small problem with my tranny. The fluid looks okay, it is a little bit darker than I would have expected but it does not smell burned and my tranny light is not coming on to indicate a problem (The bulb does work). I can switch overdrive on or off with no problems.
Wanting to be kind to my car I am planning on using Royal Purple in it because of the reports I have heard. I know Ford now recommend 5W/20 for all Ford Focuses so the motor oil seems fairly straightforwards (Does anybody know the TSB number for the oild change because the mechanics here don't believe me). I see that the tranny requires Mercon V fluid, does anybody know whether Royal Purple ATF would be up to the job and if so, what type should I use? Whilst I am asking, what is the best coolant I should use in the radiator?
Also, the tranny is a 4F27E ... I would like to change the fluid but do not see a drain plug, am I blind or something? I assume it is not necessary to remove the pan and that changing it 2 or 3 times will flush out most of the old fluid. If somebody can explain how it should be done that would be great.
