hey
yeah, it was [drinking] 30... for a few hours ha ha ha
but now i can think... its dam easy to get lights wired in
im not to sure how to get into where the reverse light/brake light houseing is... so thats on your own.
Find the wire going to the reverse light that has power when you flip it into reverse, use a test light.
use a quick connect off of that to go to the relay,
then, run a power wire... how ever you would like from your batt, (inline fuse under your hood) back to the rear of the car.
find a safe location for the relay where you can wire in the the wire from the reverse light and the bat wire, you could place it by or under your spare tire and make a small hole in the bottom to go to the light.. if theres an opening.
add in the reverse light where you want it, then run the wire from the relay..
so with out being able to draw a picture.. it would kinda work like this...
Power feed from bat, to relay.
Kicker wire from reverse light power feed, to relay kicker post.
power out from relay, to lights.
when you put it into reverse, the power goes threw the relay and draws directly from the bat.
pm me if you want any more... specific...directions...
or if your in PA, i might be able to do it
