Got them installed. Not that difficult. Took about a hour to do both.
Had trouble removing the driver side turn signal bulb from the grill, so had to just unplug the connector. One of the three indexing tabs would not let the socket out of the grill housing. Someday if I have to replace the bulb, will have to break something to get it out. You twist them counterclockwise to remove them from the grill.
Everything went together except for one thing. On the passenger side underneath, the car body mounting bracket hole would not align with the headlight tab. It was al least 1/2 inch off, so just left it out. Could not even bend the metal tab enough to get it closer. The top mounting screws are holding it plenty secure. Drivers side was fine.
Was surprised that the wire gauge in the OEM was so small, looked like it could be 20ga or so. The TYC looked to be around 16ga.
It was good to see that the bulb clamping mechanism is just like OEM. I have read that some brands have changed the way the bulb is held in. Not that I am a fan of the OEM clamp, but I find that I change the bulbs without removing the entire housing from the car.
Waited until it got dark to do some adjusting. Both sides were way off. You can't use these out of the box. By the way, they came double boxed from RockAuto, very nice.
OEM
[/URL][/IMG]
TYC
[/URL][/IMG]
No headlights
[/URL][/IMG]
New installed
[/URL][/IMG]
