Had my candy apple red 2012 SEL delivered mid-August (August build). It is a canadian verions with DRL's. Noticed that when the light switch is in the off position, the DRL's are on as they should be, however all the parking lamps are also one with the green parking lamp indicator on the dashboard is on. Going to the parking lamp position on the switch, the parking lamps remain on as well as the green indicator, but the DRL;s go off (which I did not think was allowable under canadian law, however this allows for putting on the fog lamps with the DRL's and headlamps totally off). Moving on to the on position, all lamps come on, both parking as well as headlamps. Finally the auto position does switch between DRL and full headlamps depending on the outside light, however again, the parking ligths as well as the green indicator is always on as it is in any lamp switch position. Tried another SEL at the dealership and it exhibited the same behaviour. Do other Canadian Focus owners see the same behaviour?
