1 - 6 of 6 Posts
I'm doing a head swap with my cougar. dropping on a head from an '01 focus so i can install new cams. I'm wondering if anyone here has the wiring schematics for the cmp sensor. I just need to know which pin on the sensor is going to be signal.. thanks in advance!
FF Affiliate
It wont work that way , you cant use the intake cams from a focus to tell the ECU what the Exh cam from the cougar was doing
Just leave the cam sensor off/unplugged you will be fine
would it still run good with the cam sensor unplugged?
this is old.. but figured I'd bring it back just incase someone drops by.
I ended up connecting it.. and leaving it disconnected.. neither had any positive effect.
FF Affiliate
The reason it didnt hooked up is the ECU was getting the wrong signals and wouldnt use them , Like I said it does not need to be hooked up at all , Glad you got it going
1 - 6 of 6 Posts
