1 - 7 of 7 Posts
OMGVTAK!
I believe it would be better to use 2. Why would you want just 1 for?
i think it would be a waste or money, you probably wouldn't make anywhere near the same gains as with two, and you're going to have to get your car dyno tuned again if you buy another gear later
Late for Dinner
I can see this now[rolleyes]
next will be...help! my car wont run because i have no clue what the hell i'm doing or how to properly time this motor!
one is worthless. two are just as wothless if you don't have it properly dyno tuned to find where the best gains are.
just slapping some on isn't instant horsepower. every motor reacts differently to different settings.
save your money until it can be done right. even then don't expect huge gains by any means.
first mod should be a good exhaust, second a cai. once it can breath, other mods will work better (i.e., cam gears, cams, tb, etc.).[thumb]
you can do one....
but there is no point on buying only one...
you will need 2 to get the most of the car..
if price is the problem..
wait till you find a good set of used gears (as i did)
1 - 7 of 7 Posts
