1 - 2 of 2 Posts
Was jus wonderin if anyone knew a way to adjust the camber of the rear wheels on my SVTF without buyin a kit because it is too positive and causing the right rear wheel to rub against the inside of the wheel well. Anyone else have this problem when they lowered their car?
Did you install yourself? If you did then I suspect that you should go back to the SVT specs on what it says. If you did install take it back and kill the dude who did it!!!
Also, i thought that you are just putting the car down an inch so the camber, caster and toe adjustments should be the same. It's like putting springs on, all you have to do is readjust unless you do autocross.
Also call Ford Dealer they will tell you the specs for stock.
1 - 2 of 2 Posts
