The cams being set to 0/0 is trivial. There is always a little play either in the cam bar or when the engine is running. That tiny bit of play can alter cam timing. For the most part though it won't be noticeable.
And I know this won't pertain to the cams at hand but,
http://www.focusfanatics.com/forum/showthread.php?t=259167
As you'll notice by the bell curves, at the beginning and end of the ramps variations of a cam degree or two won't make any difference. But when you get near the peak of the cam lobe it'll make a huge difference, or can.
The goal is to match the timing of the cams to what your intake and exhaust flow/velocities wants. That is where the dyno comes into play.
I've sat and played with every equation I could find as well as making a few of my own to try and find a quick path to getting close to perfect timing. It's not possible, but I did learn a few things along the way.
You can get kinda close doing the compression thing. But who's to say how much you leave on the table or where you're making sacrifices.
