^Correct.
An engine with the same header/intake manifold and cam combo will dyno virtually identical to all others.
All adjusting the cam timing will do is move where the TQ peak is. And the limitation is the duration and ports.
Modify the head, moving the cam can make a difference / may be needed.
Also (as I've said in the past), the lash can either add or subtract from the actual duration.
The ONLY way someone's stated advance/retard numbers would transfer to someone else's car are if the exact same combo were used. That is same exhaust, intake manifold (anything before the manifold is moot), cams, headwork and lash settings.
That +3, -2 is simply making up for lash being off from what the head wants. I'd bet if people would post their #'s and their lash that this would become apparent and that an optimal lash could be found negating any need for adj. gears.
And degree wheel,
I made one. Printed a CD with an image of a degree wheel and bolted it to the cam. Easily something anyone here could do. From there it's just a matter of understanding the numbers.
Also, if anyone could benefit from adj. gears it'd be me. When you delete the VCT from the SVT head you can't use the cam bar to line the cams up; the intake has to be retarded and I've found that doing so with adjusting the cam gear just doesn't move it enough. You can search on that if it's unclear.
Simply put, my intake cam is ~25* away from where the bar would fit in. I haven't moved either cam since I put it together/dyno'd. Could there be more power, maybe. Am I going to move them and find out, no. A couple here or there isn't going to make a bit of difference in how my car runs. It's not like I'd find +20HP by moving them.
But in a car where they are off from the get-go, you will find power.
I mean look at it this way, $300 for gears and $400 for a tune. Which is going to make more power?
And another thing, for all the cheapskates on here, I really doubt they are going to add $80/hr for dyno tuning time to find a couple HP. IMO that's just a waste.
I can think of others things to blow $500 on.
