What diff does WOT have to do with it? Well.....what are we actually doing when we move the exhaust cam timing around? Answer is balancing the opening/closing to the exhaust pressures in the system for best cyl filling.
Change the exhaust with low restriction cat or ORP, and most likely the car will drive better with the exhaust cam moved a few degrees one way or the other. Haven't we all seen engines that ran better with their mufflers installed than with the header open? At least at low rpm...that is.
WOT pressures, temps and velocities....even down at 2000rpm....are much different than light throttle and so might not be influenced so much by a degree or three.
When we install the cam gears, we get them as close as we can to perfect...yes? This means the cam timing bar fits into the slots @ TDC. But, we are prey to machining inaccuracies and variables beyond our control when we do this. Granted, if moving the cam a few degrees makes things run better, it is arguable that the cam wasn't in the proper place in the first place. But, if the timing bar fits....how are we to know that it isn't perfect? And, without the degreeable cam gear, get it 'perfect'?
So Tom.....are you saying that your testing shows NO change in power production with moving the exhaust cam -6 to +6? If so...I'm not buying it. Every engine is different and some just might run best at the factory designed setting. But....some won't and those are the ones that will benefit from the cam gear. And, unless you have the gear and have tried moving it around....how is one supposed to know that he is running his best?
