1 - 1 of 1 Posts
Replacing timing belt, water pump, etc. I turned crank to #1 TDC, and I see the notches in the camshafts for the tool are offset. Tells me if I'm 180 degrees out, no way tool is going in the notches. It appears I have the cams where they need to be, the notches are up higher in the head, but the tool won't notch in; the edge of the head is in the way. I jiggled cams a little, but no luck. What am I missing?
Thanks
1 - 1 of 1 Posts
