[twothumbs] Last winter I lived in SW Ontario, it was a pretty severe winter but my trusty 2001 Focus got me to and from work (and anywhere else) without too much bother except - I couldn't get any heat into the passenger cabin which made those journeys pretty darn uncomfortable [rant]. As the winter reluctantly gave way to spring, the needle on my engine temperature gauge did creep up a little bit [wiggle] - but by then I didn't really need it! [
This winter I will be living in Northern Ontario [sadpanda] - where the winter is going to be that much worse than (by comparison) the tropical SW!!! So in anticipation I am looking for some advice on a solution. My mechanic says the thermostat is working fine, hence temp changes are reflected in the gauge, all the fluids are in good order and so I should be good to go - right?
Then I was told that I could 'shield the front end by fixing either cardboard or lightweight plywood to prevent the cold air getting to the radiator' - but that was as much as that pundit knew so I am now turning to other Focus Fanatics to seek some advice - if this latter part is true and might resolve my frozen toes issue, then photos of what you have done would be especially appreciated. [race]
Thanks in advance... [
