1 - 18 of 18 Posts
Where are you guys putting the bypass on for your cai's?
Discussion Starter · #2 ·
bump.
Discussion Starter · #4 ·
yea, the problem I ran into was that anywhere on the pipe that would work was all crammed up between engine parts.
I wouldn't use one, honestly. The bypass only works if the filter is completely submerged underwater. It's not going to prevent condensation or droplets from entering the engine. The bypass leaks air anyway, so you usually end up with higher IATs. I ran an AEM CAI with a bypass for about a year until the whole thing fell apart (it was used and the brackets were broken already). I got another one without the bypass and ran it for another full year, 5 days a week minimum through every season, every kind of weather. Not a problem. Obviously you don't want to rev it out to 7200 when it's pouring rain; you just have to be mindful of it. A little water in your engine is not a bad thing; a lot is. Avoid the big puddles and you'll be fine.
IMO, they aren't worth it. You're better off putting a turn up on the end of your CAI to put the filter high up in the fender. The bypass valve is supposed to go in the break in the two pieces and there is no real way to fit the bypass valve in there. You'd have to cut a section out somewhere to properly fit it.
Discussion Starter · #7 ·
thanks, I'll look for a turn up.
Here's a pic of mine (after it fell off my car [boxface] ) for reference of what I'm talking about. Notice right before the filter the 90degree upwards bend. Puts it plenty far out of the way.
Moisture is going to build up in there though, isn't it? There's nowhere for it to drain out... at least with the standard CAI, it can drain out through the filter.
I never really thought of that but I never had a problem with that. I'd assume you could drill a pretty small hole and it wouldn't be an issue.
I used a $10 filter shield from Autozone on mine.... worked great.
my problem i ran into with the cai was not that it was going under water but when it rains water falls ontop of it and then u drive and water gets in it and [:)][:)][:)][:)]s up my tps sensor i installed a heat sheild on it but use it as a water shield so when water falls on it it rolls right off and no water has gotten in yet
Discussion Starter · #15 ·
ah nice idea.
Discussion Starter · #17 ·
nice, buying one of those for sure.
That was hard to read [8]
I get what you're saying, I've heard some people having this problem and some never do. Personally I never did.
1 - 18 of 18 Posts
