1 - 9 of 9 Posts
Focus "Sleeper"
Being a college student is making me think about making my own front strut bar. I know its only $100 or so, but now that I got it in my head, I kinda want to try and see if I can do it.
So my question is this: Has anyone on here done this? If not, can someone go out to thier car and do some measurements on thier strut bar? I got access to all teh round bar and steel plat and weld I could ever need, so that is not a problem. I figure I am giong to end up designing it as I go, but I was hoping someone could give me some numbers so I know where to start.
Thanks for checking in!
Design it so you can attach it to the firewall, that way it can do something, I'd even buy it even though I already have the Focussport one.
Focus "Sleeper"
Against the firewall??? Isnt that where the fusebox and clutch/brake booster is?
Yes, but there may be room to bolt it around them, I really am not sure I was just throwing the idea out there to see if it could be done
the strut its self is 19 to 20 inches, there is a front suspension lower arm ball
joint are you looking for the lower arm as the strut bar or are you looking for
the strut its self?
its a very cool idea!!! strut bars 20 inches????!
There's no practical way to install a straight strut bar due to under hood obstructions and limited space, All the aftermarket bars for a Focus have convoluted alignments. Every bend weakens the effectiveness of the bar. Because of the routing there's no practical way to give you measurements and angles. I suggest you design a pattern with some steel rod (1/8" or so) and then transfer those lengths and angles to some high quality steel tubing. A triangulated brace (see my avatar) is the superior and preferred design, but once again, it would be very difficult to do on a Focus.
Focus "Sleeper"
Discussion Starter · #7 ·
Well I figured I would be doing little triangle braces on the bends, but it is good that someone else on here is thinking along the same lines.
Yes, I am talking about a strut tower brace.
I may have to just wing it from here. Oh well. Anything would be better than what I got (nothing).
If you could tie it in to the firewall just below the cowl that would strngthen the subframe as a whole.
I'm buying a used one and once I bolt it up I plan on adding to it so that it'll be tied in to the firewall...I'm hoping to line it up in the middle but we'll see.
We may be getting away from the intended purpose of a strut bar which is to strengthen and prevent the strut/shock towers (and the strut or shock) from flexing inwards and outwards. Mounting a strut bar to the top of the tower or the strut/shock is a time proven way of doing this. As surprising as it seems the top of the shock/strut can transmit considerable loads to the chassis in undesirable vectors (directions).
1 - 9 of 9 Posts
